Drive the front tires into a ditch 18 inches below the rear. Use an air fitting on the reservoir (Vent unit hole with schrader (valve stem) valve adapted. use a tire pump, or regulated air pressure to put a max of 20 PSI in the reservoir. start it and work the valves and steering (if power). Best of luck. Jim
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
