Posted by Janicholson on June 21, 2011 at 20:53:15 from (67.72.98.45):
In Reply to: 504 hittin on 2 cyl. posted by Jay Rider on June 21, 2011 at 08:48:40:
Using a pair of insulated pliers, pull off one plug wire at a time (plug end) If a cylinder is missing consistently, it will make no difference. If it is running consistently, it will probably kill the engine. Note which of them make no difference, If they are 2 and 3m it could be a head gasket between them. Consistent misfire leads to a compression check (after what you have done, and finding which are not working) A cracked or loose intake manifold can also have this effect if the compression checks out. At or more than 120 PSI each, + or - 15 PSI. throttle open, charged battery, all plugs out, and at least 5 compression strokes. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
