Re: Farmall M front bolster
Posted by sflem849 on June 22, 2011 at 04:56:30 from (69.197.84.78):
In Reply to: Farmall M front bolster posted by IAtractorKid on June 22, 2011 at 04:35:36:
I think no part of that setup is original to the era so it wouldn't really matter what type of weight you use. I wouldn't go too nuts putting weight on those two threaded holes. I have seen a couple that have broken off.
When I pull I took a couple heavy I beams and bolted them to the holes in the frame rails. They take suitcase weights nicely. If you just want a quick adaptation I have seen guys bolt half weights to the same holes and run with it.
