Re: WD9 wheel locked
Posted by rustyfarmall on June 22, 2011 at 09:46:10 from (216.248.71.224):
In Reply to: WD9 wheel locked posted by DG409 on June 22, 2011 at 09:37:07:
I will guess it is the brake that is locked up. Should be 5 or 6? bolts holding the brake cover on. The brake band is SUPPOSED to come off with the cover, but if it is all rusted up inside it probably will not be easy. You can fix the brake problem AFTER you get the tractor home.
