It needs to be on the compression stroke. Put a thumb over the hole and crank until pressure is coming out of the hole. Stop and then use the straw. to assess TDC. The mag impulse coupling must be cocked so that just as it gets to tdc, it fires. The mag must be in place, and retarded. Then the engine rotated to compression TDC, then the mag turned till it trips(click/spark) then tighten it down. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
