Re: How do you attatch the third set of wheel weights?
Posted by sflem849 on June 22, 2011 at 15:13:31 from (69.197.84.78):
In Reply to: How do you attatch the third set of wheel weights? posted by sflem849 on June 22, 2011 at 05:33:45:
IH H-4 Mag
I'm not sure I can justify sticking money into this one. I am $800 deep in it and it has some major problems.
The block was cracked and repaired. Now when I went to start it today it started spitting coolant out the exhaust.
The trans jumps out of third and when I opened it up I saw a few chipped up gears (that wern't third)
The rears are older and slightly cracked but very useable. The fronts are just tires.
The rear drawbar is perfect with new mounting hardware.
Could I part it out and be in the black? I KNOW if I fix it I would have a tough time getting in the black.
