Re: Farmall governor help!
Posted by Bruster on June 22, 2011 at 17:32:49 from (98.27.230.190):
In Reply to: Farmall governor help! posted by Bruster on June 22, 2011 at 04:55:23:
Fixed!!
Problem with it not meshing was that the replacement gov was also off off an H, and had it's drive gear left on..................
The friggin gear was 1/8" WIDER than the one coming off the tractor, with the SAME # of teeth.
The shaft connections between the carb and gov look like where the problem was!....Thanks guys!
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
