Re: Farmall governor help!
Posted by Bruster on June 22, 2011 at 17:37:36 from (98.27.230.190):
In Reply to: Re: Farmall governor help! posted by rustyfarmall on June 22, 2011 at 08:20:28:
Gear was already on never taken off the replacement. Found it to be a larger diameter than ours by1/8"...........ain't that a kick?!
I was describing the sound like when older Detroit's bounce on the governor when cold and it sounded just like what this H was doing.
