Re: m block boring
Posted by wijd on June 22, 2011 at 18:14:42 from (74.220.11.32):
In Reply to: m block boring posted by lee oh on June 22, 2011 at 07:10:50:
If you want 450 pistons pull the sleeves out take the block to the machine shop and have it power honed. The 450 pistons will run right in the block with no sleeves. Depending on how much you shave off the head and how much dome you have on your pistons you may need to get filler rings to keep the head gasket from blowing or get a copper head gasket. The disadvantage to this is you are wearing in block and basically making a thow away block after its wore out. The wear before the block is ruined will take thousands of hours.
