Re: Farmall A PTO
Posted by JRSutton on June 22, 2011 at 18:36:49 from (75.130.109.233):
In Reply to: Farmall A PTO posted by tinny on June 22, 2011 at 16:13:38:
the belt pulley speed, with no load, is 1272rpm
And the pto speed is around 540rpm (don't quote me on that one, but in that ballpark).
That's at an engine speed around 1500rpm (again - going from memory on that one, but I think that's close)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
