Posted by Paul in CT on June 22, 2011 at 19:00:42 from (70.138.1.157):
Went out after work and checked the compression. 110 psi on each cylinder. Adjusted the valves to 0.017. i had not removed the old manifold so i did not put a new gasket on.
Tried to start it and nothing. Poured gas into the carb and it ran for 5 seconds. Took the carb off and took it apart. The main jet was plugged and I could not get air to pass through it. This was plugged BEFORE I sent it out to be "rebuilt". I would have done it myself but someone before me had just about stripped the slot out of the main jet. Thought I should have a "professional" work on it. Guess I was wrong. Will be calling the carb shop tomorrow.
Are new main jet available since it looks like this one will have to be drilled out or should I just buy a new carb?
Thanks for all your help and I will keep you posted.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
