Re: h farmall manifold
Posted by pete 23 on June 22, 2011 at 19:50:10 from (74.32.230.16):
In Reply to: h farmall manifold posted by rick deere on June 22, 2011 at 18:23:18:
The after market manifold is made for H and Super H so it has a slotted mount for carburetor. I have one on one of my H tractors and it seems to be more difficult to get a consistent nice idle. You set it so it idles nice at the lowest end and it tends to be rich at a moderate speed. It may be my carburetor but I attribute it to the difference in throat of manifold to carburetor.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
