Re: 504 hittin on 2 cyl.
Posted by Red Mercury on June 22, 2011 at 20:18:29 from (206.45.234.17):
In Reply to: 504 hittin on 2 cyl. posted by Jay Rider on June 21, 2011 at 08:48:40:
I have a 504 (gas) as well and it had a very similar problem. After checking ignition components, fuel system, etc., I eventually found that the intake manifold gasket was leaking. It was a big enough leak that I could press a rag against the leak and the engine would run much better. I installed a new set of gaskets--an easy fix.
