Posted by TC2 on June 23, 2011 at 05:04:01 from (132.79.10.15):
In Reply to: m block boring posted by lee oh on June 22, 2011 at 07:10:50:
I have a 51 M with 450 sleeves in it. It can be done. It is correct that there isn't much metal left after boring the block for the sleeves, but a lot of that depends on the condition of your block to begin with. There is an engine builder nearby that regularly puts 450 sleeves in M blocks. I have even seen them break through to the water jacket slightly, but when the sleeves are set, this isn't a big issue either. I say go for it!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
