I did what John suggested. Just did it last week actually. I bought 3/4 inch (if i remember correctly) allthread bolts. (they are a bolt that has no head to wrench on, just thread from end to end) I put a flat washer on, a lock washer and then a nut, i then put that through the rim facing away/sticking out from the tractor, (put it in through one of the 4 wheel weight holes cast into your rim) i then took a nut and screwed it onto the allthread bolt, this leaves the bolt fastened securely in place to your rim, do the same for the other 3, then you can easily slide as many wheel weights on as you want, works really slick. If you have ? shoot me an email.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
