Re: Farmall A PTO
Posted by d7 Fever on June 23, 2011 at 05:51:37 from (74.106.74.16):
In Reply to: Farmall A PTO posted by tinny on June 22, 2011 at 16:13:38:
if you are putting a belt pulley drive on the tractor for the first time, you might need shims, if it is already on there it probably has them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
