Re: Rusted Muffler Pipe on H
Posted by Dean Olson on June 23, 2011 at 06:21:05 from (166.205.10.60):
In Reply to: Rusted Muffler Pipe on H posted by Jim Paterson on June 22, 2011 at 19:14:24:
I interpreting your post as you want to remove the muffler from the manifold pipe without destroying the muffler, manifold, or manifold pipe.
Heat up the connection and wiggle it till it comes loose. You just want to heat the muffler material, so just it expands,and not the manifold pipe. Don't cook it. If that doesn't work. Try tapping the bottom of the muffler, straight up, with a rubber mallet. If it still won't come off employ the bigger hammer theory and whack it till it comes off. You may not be able to salvage the muffler if it's that rusted up.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
