Re: 460 Diesel Hydraulic issue, again.
Posted by RedRoundhead on June 23, 2011 at 07:19:44 from (24.106.38.186):
In Reply to: Re: 460 Diesel Hydraulic issue, again. posted by Tod Michigan on June 22, 2011 at 18:38:16:
The Tel-a-depth spool valve "floats"?self-centers when not called upon. So if it is bining, or stuck, it will cause problems. Basically, when you move the lever on the teledpth quadrant, it tells the spool valve to flow oil, in a certain direction, and the linkage tells the spool valve when to stop flow. So if the linkage is out of adjustment/compromised, it will affect the "normal" operation of the fast hitch.
