Re: h farmall manifold
Posted by Michael Soldan on June 23, 2011 at 16:00:20 from (24.235.38.54):
In Reply to: h farmall manifold posted by rick deere on June 22, 2011 at 18:23:18:
Buy a new one. The new one has better flow and is not restricted with rust and pit marks which cause poor flow. The tractor will run like new again,I've gone both ways and the new manifold was without doubt the best investment,you have a new surface for the gasket and the performance justifies it.As was stated,they are slotted to accept any size carb body.I had a distillate manifold welded,ground flat,tons of work, had the surface planed,spent more than a new one and still had an old welded manifold.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
