Re: 1946 Farmall H Hyd Pump and Generator
Posted by Pat-CT on June 24, 2011 at 19:06:20 from (68.9.37.25):
In Reply to: Re: 1946 Farmall H Hyd Pump and Generator posted by rustyfarmall on June 24, 2011 at 13:40:28:
Agreed to what rustyfarmall said. There is a belly pump, With a
control rod attached that leads up to the operator station.the pump
itself is located under the battery box area, in front of the belt
pulley (if equipped) And if it was equipped with electric start, it is a
6v positive ground system.
