Re: Rochester gas gague float change...
Posted by Crazy Red Power in SE-WI on June 24, 2011 at 19:31:04 from (24.183.132.223):
In Reply to: Re: Rochester gas gague float change... posted by Wardner on June 24, 2011 at 18:08:07:
Wow, I did spell like a putz! I thought something didn't look quite right about that post. Anyhow, the replacement float is a new rubber one with the brass grommet that operates the actuator for the needle. I don't know if I want to cut all of that in half. The fitting holding the wire legs seems to be crimped on, so I might be able to solder the fitting after I get it off. I'll give that a try.
Thanks,
Mike
