Almost forgot important Fire Crater Piston info...
Posted by Crazy Red Power in SE-WI on June 25, 2011 at 12:07:44 from (24.183.132.223):
for YOU guys (an' gals). I was researching some info for my baler on CaseIH's manuals site & figured I would do some searching for some other bulletins for miscellanious odds 'n' ends. I found a bunch of tune-up spec sheets for when you install the Fire Crater Piston package in your H, W4, M, W6, etc. I don't know if the instruction sheets would apply to the current Fire Crater type sets, but I don't see why not. Anyway, it took a bit of working with the people in CaseIH's research dept. (a very patient bunch) & I was able to get them released as a standard printout you can order through the mail or download as a PDF. Not expensive either. Hopefully, some of you can benefit from this info.
Mike
