Re: Farmall 230 stalling
Posted by bobs old iron on June 25, 2011 at 21:11:35 from (75.171.159.228):
In Reply to: Farmall 230 stalling posted by John in Red Hook on June 25, 2011 at 20:23:25:
you will replies other than mine/////first you need to find out if it's fuel or electric causing stalling. do you get spark after shut-off, by checking spark jumping from wire to plug while cranking, or is it loosing fuel to carb, check in tank to make sure something isn't covering fuel hole, check fuel bowl if h2o, dirt etc plugging pick up flow of fuel.....and what anyone else has for you...
