Re: Which PTO adapter do I want ?
Posted by old on June 26, 2011 at 10:03:52 from (209.86.226.19):
In Reply to: Re: Which PTO adapter do I want ? posted by Super H Mike on June 26, 2011 at 09:58:05:
ORC or over riding clutch is a racket sort of thing for the PTO and it keeps machines like brush hogs from pushing a tractor when the clutch is pushed down as in non-live PTO tractors which most of the older ones are like. Cost is not cheap but worth it in the long run since it could well save your life. In $$ around $50-70
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
