Re: Farmall super c
Posted by TWheat on June 26, 2011 at 12:07:00 from (67.233.24.90):
In Reply to: Re: Farmall super c posted by farmallsuperc on June 26, 2011 at 09:56:56:
third party image
If you move the touch control lever/levers ,it/ they are gonna move.I would plumb the bypass to a separate valve and plumb that to the cylinder to lift the rear implement. Use only the lever on the new valve (with a built in relief valve or a added relief valve) and don't move your touch control levers.I don't know if the right hand arm on your touch control works your plow, I would guess so. If so it might not interfere with the rear implement position, BUT, my touch control needs to be re-Oringed and cleaned since either touch control lever wants to wiggle both arms. Pic of my second valve.
