Re: 656 smoking
Posted by Bill in NJ on June 26, 2011 at 12:17:15 from (4.248.93.59):
In Reply to: 656 smoking posted by andy stockmaster on June 26, 2011 at 09:29:45:
656 burning oil. likely suspects = piston rings or valve guides. Do a compression test. If compression is within spec you most likely need a valve job. If compression is low, squirt some oil in each cylinder and re-do the compression test. If the compression rises, the problem is rings.
'H' starving for fuel. Keep in mind the 'H' has gravity feed fuel system. Any restriction will create fuel starving. Check lines, filter bowl, carb and tank outlet for blockage. Do not use an add on in-line filter. They cannot flow through well enough for non-pressurized system.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
