Re: SA Starting Problem
Posted by old on June 26, 2011 at 16:15:49 from (209.86.226.27):
In Reply to: SA Starting Problem posted by Doug Kieta on June 26, 2011 at 16:09:23:
First off charge the battery. Then if it has a starter button that is not part of the ignition switch run a hot wire from the battery to the coil. Be sure you hook it to the ignition side of the coil. Try to start it. If it runs then you know the ignition switch is bad and it is as simple as replacing the switch with a new on and just unwire it one wire at a time and hook each wire one at a time to the new switch
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
