Re: H belt pulley engagement rod
Posted by carpman15 on June 26, 2011 at 18:54:50 from (71.82.165.184):
In Reply to: Re: H belt pulley engagement rod posted by dep on June 22, 2011 at 10:58:09:
if you want if you were to tell me what one you needed i could get you one next time i go up to the salvage yard
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
