The no shutdown problem is a bad kill switch ("ignition" switch). Either the switch itself is bad, or the box it's mounted in is not grounded to the tractor frame. (Keep in mind the kill switch works by grounding the magneto primary when turned off so the mag won't send fire to the plugs.)
The dead battery can have several causes:
1 - Battery is worn out and will longer hold a charge.
2 - Charging system has problems and is not charging the battery when the engine is running.
3 - The cutout (or the cutout relay inside voltage regulator if so equipped) has stuck in the closed position causing the battery to discharge when the engine is stopped.
To figure out which it is, watch the ammeter:
If it shows charge when running and 0 when stopped, you need a new battery.
If it shows 0 at all times (running and stopped) either the generator or cutout has failed.
If it shows charge when running but then discharge when shut down, problem's a stuck cutout/voltage regulator relay.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror
... [Read Article]
Latest Ad:
[More Ads]
