Re: Serial number meanings
Posted by randy hall on June 27, 2011 at 05:19:24 from (209.143.10.204):
In Reply to: Re: Serial number meanings posted by Bob on June 26, 2011 at 22:03:47:
bob you're a little bit off. the x1 is gasoline, highest compression. the distillate was medium compression and the kerosine was the lowest compression.+
