Re: 460 diesel POWER STEERING ISSUE
Posted by IH fan on June 27, 2011 at 16:27:52 from (99.103.254.184):
In Reply to: 460 diesel POWER STEERING ISSUE posted by ghanson on June 26, 2011 at 20:51:08:
If you have flow, the pump is turning... should not be a disconnect between the pumps. You have a problem elsewhere in the system and the most likely suspect is the relief valve has something sticking it open, or a problem in whatever valve controls steering direction. Most of these relief valves are "pilot operated". meaning there is not a main spring controlling the pressure, but a pilot circuit that "feeds back" from the system pressure. Does not take much contaminent to plug them up.
I have worked on a 460U, but as I recall, all I did was change the main pump from the standard 12 gpm to the optional 17 gpm. This was to run a field test at Cessna, running a bush-hog type mower with a high torque hydraulic motor in place of the PTO gearbox.
