Re: H M manuals
Posted by CNKS on June 27, 2011 at 17:25:02 from (216.144.104.128):
In Reply to: H M manuals posted by Bill Bowen on June 27, 2011 at 17:04:39:
Numbers are correct. M has about 36% more HP and about 25% more weight. Perhaps overkill at first, but the last 4 cyl tractor in the M series (450) had the same rear casting and 51 HP or twice that of the H; the last 4 cyl tractor in the H series (350) had basically the H rear casting and about 37 HP.
