Re: Rear Wheel Removal
Posted by Greg Meadors on August 07, 2000 at 22:35:53 from (152.163.197.81):
In Reply to: Rear Wheel Removal posted by Jon on August 06, 2000 at 17:18:22:
I have an H with both rear wheels being liquid filled. They are extremely heavy. That being said, I was able to jack one side up, remove the rim and then reverse the hub. To reinstall, I lowered the hub just a bit and then slid the rim up on the hub. I then jacked the hub back up just enough to allow the rim to swing onto the hub and then tightened it all down. Worked great. Since I do not have any hoists I had to improvise. One thing you do not want to do is let a wheel get away from you. Keep it upright. If it starts to fall, get outta the way!! BTW, I am 6'3" and about 225 but two of me could not hold one wheel. Good luck and be careful.
Post A Followup
: Re: Re: Rear Wheel Removal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
