Re: 1974 farmall 140 hydraulics
Posted by Janicholson on June 27, 2011 at 20:20:31 from (67.72.98.45):
In Reply to: 1974 farmall 140 hydraulics posted by Kerry Latiolais on June 27, 2011 at 19:20:26:
If you can change the lift arm to the other rock shaft, you can tell if it is system wide, or only that internal cylinder. I suspect it is a pump issue, though it could be a partially stuck pressure relief valve (particle holding it open). Jim
