Re: 460 diesel POWER STEERING ISSUE
Posted by Tod Michigan on June 27, 2011 at 23:03:32 from (174.252.231.13):
In Reply to: 460 diesel POWER STEERING ISSUE posted by Tod Michigan on June 26, 2011 at 20:51:08:
If I have flow out the PS return line and as someone requested there is an obstruction in the steering bolster or anything between the pump and the obstruction, wouldn't I still show the Max pressure from the pump if I have a pressure gage in the test hole on the manifold plate?
What I'm thinkin is because I can't produce more than 200psi and I seem to have the correct volume of flow(1gallon in aprox 20 seconds) wouldn't this suggest that I Have a relief valve issue rather than a bolster issue or something similar???
Thanks guys,
Tod.
