Re: 460 diesel POWER STEERING ISSUE
Posted by IH fan on June 28, 2011 at 02:50:25 from (99.103.254.184):
In Reply to: 460 diesel POWER STEERING ISSUE posted by Tod Michigan on June 26, 2011 at 20:51:08:
If you have flow out the return port from the bolster and no pressure in the system, there must be a bolster problem. If there is no flow out the reurn port, then it could be dumping over a stuck relief valve... wasn't taking the flow out the bolster return port into consideration in my last reply. If relief was stuck open, I think on those, the flow dumps right back into the inlet port of the pump and you would not have flow through the rest of the system.
This post was edited by IH fan at 02:51:32 06/28/11.
