Actually there is a difference between them and the later models. The ones built by IH had a cast iron transmission case - same as the Farmall Cub. A few of the early MTD versions had the same case as they burned off parts. Then they went to a aluminum housing on the transmission case.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
