The basic hydraulic system on a 1954 Super H is a ONE-way system. All you will have is the hydraulic "block" under the gas tank, and one lever.
There are two ports on a casting that protrudes from the rear of the hydraulic block on the left side. Those are your pressure/return ports. BOTH ports provide pressure when you pull the lever back, and BOTH ports allow the fluid to return when you push the lever ahead.
Two-way hydraulics are an add-on. You need a separate "open center" two-way valve. To hook it up, you connect one of the one-way pressure/return ports to the IN on the valve. You connect the OUT from the valve to the 1" drain hole located on the back of the hydraulic block on the right side. Mount the valve somewhere convenient. Run hoses from the "work" ports on the valve to the rear of the tractor and install quick-connects.
To run the two-way valve, you first lock the lever on the hydraulic block in the "back" position. Now oil flows through the two-way valve, which you can use to control a two-way cylinder.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
