Re: 240 hydralic lift
Posted by mkirsch on June 28, 2011 at 06:46:22 from (64.80.110.75):
In Reply to: 240 hydralic lift posted by steve phillips on June 28, 2011 at 01:56:53:
The hydraulic fluid is also the transmission fluid on a 240.
Fill should be on the top of the operator's platform, between your legs.
Drain is on the underside of the tractor, near the back.
Level check plug should be on the left side of the tractor somewhere near the clutch pedal.
You should get an owner's manual that tells you all this stuff. Reprints are available from many places on the internet.
