Posted by Bob M on June 28, 2011 at 08:46:34 from (67.240.171.41):
In Reply to: oil in distributor posted by SMTA on June 28, 2011 at 07:59:31:
Most likely it's hydraulic oil leaking from the live pump pump. The oil is filling the distributor drive housing (gear box) then following the shaft back into the distributor.
Only fix is to replace the rear seal on the hyd pump.
Good chance the pump's also leaking oil from the front seal into the crankcase - good idea to replace BOTH pump seals.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
