Re: H Governor Surge Screw Adjustment
Posted by pete 23 on June 28, 2011 at 09:59:25 from (74.32.230.16):
In Reply to: H Governor Surge Screw Adjustment posted by big a on June 27, 2011 at 20:29:04:
First off, take the surge screw out to see if there is in fact a spring in it and is not broken. To adjust, just turn it in while running at the speed it wants to hunt, turn in until smooths out and then check low idle. To much and it won't idle down. I like to see them bounce once or twice to assure a good active govenor. If spring is gone you can most likely find one at the hardware store, just a light compression spring.
