Re: 460 diesel POWER STEERING ISSUE
Posted by Tod Michigan on June 28, 2011 at 10:29:25 from (174.252.229.21):
In Reply to: Re: 460 diesel POWER STEERING ISSUE posted by pete 23 on June 28, 2011 at 10:12:32:
Thanks Pete23, I'm gonna pull the pump and disassemble the check valve and maybe even split the pumps and make sure what's goin on in there. Maybe before I drain everything I'll disconnect the return line again and see how the wheel turns with the line disconnected and also observe the flow rate while I turn it. So, looks like I have some work to do. Could be worse, it could be snowing!
Tod.
