Re: Favorite Engine Un-stuck-ing Mixture????
Posted by JRSutton on June 28, 2011 at 18:19:43 from (75.130.109.233):
In Reply to: Favorite Engine Un-stuck-ing Mixture???? posted by FarmallJon on June 28, 2011 at 17:38:18:
Are you saying INSTEAD of pulling the head? or once you pull the head?
Personally I wouldn't even consider doing it without pulling the head.
I've seen some NASTY corrosion develop from less than two years of sitting.
Or course, it does depend on your locale, and how the tractor was stored. But here in the northeast with lots of moist air and wide temperature swings - a cylinder can get thoroughly encrusted in a years time.
You can free them up, but if you start an engine with that much crud in it, you're just grinding your cylinders down needlessly.
At a minimume, I'd pop the head, use a cylinder hone lightly on the areas you can see if they're caked in rust.
Wipe everything out the best you can.
THEN throw in some atf, and you can make sure you get it all around
Give the pistons a good smack with a hammer and block of wood (don't go too crazy). Sometimes that'll be enough to free them up.
If so - crank it a few times - wipe it out - wash rinse repeat.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
