Re: Farmall 300 Eliminate hydraulic pump ???NEED HELP ASAP
Posted by mkirsch on June 29, 2011 at 05:02:35 from (64.80.110.75):
In Reply to: Farmall 300 Eliminate hydraulic pump ???NEED HELP ASAP posted by Chris Klein on June 28, 2011 at 19:02:13:
I believe the difference is only in the location of the top hole on the 1950+ tractors.
I've read accounts where people have hogged out the hole on the hydraulic pump to make it fit the older front cover, and ran it that way. You might be able to do the opposite on the distributor adapter in this case, if it's the wrong one.
