Re: Farmall 706 Alt. Light stays on
Posted by Allan In NE on June 29, 2011 at 07:13:30 from (148.66.88.254):
In Reply to: Farmall 706 Alt. Light stays on posted by scottsphere on June 29, 2011 at 06:54:19:
Hi Scott,
First order of business is to make darned sure that the belt isn't slipping. If you can turn that alternator fan by hand, it's too loose.
The regulator isn't the problem as it isn't getting enough juice from the alternator to keep it pulled in.
If the belt is good and tight, the problem probably lies in the alternator. Those early alternators were weak in that they would loose a positive diode (light stays on with key off) or a leg of the stator.
Open it up and see if a third of the stator windings have turned black.
Allan
