Posted by Tod Michigan on June 29, 2011 at 07:18:19 from (174.252.247.156):
In Reply to: 184 hydraulic lift posted by kenneth house on June 28, 2011 at 19:21:25:
Some possible issues could be: clogged filter, leaking suction line, faulty pressure regulator valve, safety valve stuck open, fluid could be leaking past lift cylinder, check valve stuck or bad o-ring, and possible pump failure. If you can get a 3,000psi gage and do some pressure testing, it might save you some work and time. Good luck. Tod
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
