Re: 806 Diesel Overheating problem
Posted by Super H Mike on June 29, 2011 at 14:23:04 from (76.164.144.191):
In Reply to: Re: 806 Diesel Overheating problem posted by Pat-CT on June 29, 2011 at 03:58:03:
I don t think it will be the stat based on the description of the problem. It will run a long time before getting hot correct ? Thermostat is there to control minimum temp and will cause overheating if stuck, but within minutes of starting the tractor, not after using it. Sounds like the radiator is partly clogged to me. Water pump impeller problems are extremely rare in my expierence (25 years in auto repair),slowly building of heat to boilover makes me think the rad is not shedding the heat the engine is making. Head crack or gasket is also a suspect, causes air pockets in cooling system which disrupts flow and makes hot spots. Makes sure fan pulls good airflow too.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
