Re: My new farmall A
Posted by Janicholson on June 29, 2011 at 20:16:06 from (67.72.98.46):
In Reply to: My new farmall A posted by dwizum on June 29, 2011 at 12:49:38:
Loosen the nut first and figure out what is worn.
If just loose, locktite stud and bearing mount will help lock it up, If damaged, welding and filing will be needed, Some had a woodruf Key, I do not know which. A dremel tool and a larger Key are the answer to that problem
Many ignore the seals and put Mobil 1 red synthetic chassis grease in the box (or John Deere Corn head Grease). Those do not leak out, and are a permanent solution, Jim
