Take the hood off, and go for a drive. Watch for movement in the steering shaft. Common causes are the universal joint in mid-shaft, the little ball bearing behind the nut at the front of the steering shaft, bad wheel bearings, worn sector gear in the top of the bolster, and even loose bushings in the bolster itself. In my experience, the ball bearing at the front of the steering shaft where it terminates was the culprit.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
