Posted by ktm911 on June 30, 2011 at 14:40:21 from (216.211.52.36):
Hey guys, just doing maintenance on my farmall (replacing and fixing parts up) and I am working on the hydraulic cylinder and valve unit. The problem I have is getting the cylinder head for it off. I have removed all the bolts and the drain plug, however it seems stuck on like it almost wasn't a separate piece. The IH I&T shop manual says nothing of any additional bolts or internal parts that would cause this. Its a 4-arm model, and still has pressure in one cylinder enough that it cant be moved much either way. The other cylinder is slow but movable. Any advise appreciated. Thanks
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
